look for engineer for scripting "convert to multicolor" in photoshop 2015cc with switch.
tomchen506@gmail.com
Post by tomchen506@gmail.com »
Reference to these three attachments, please.
Re: look for engineer for scripting "convert to multicolor" in photoshop 2015cc with switch.
Like as below: Could some develop the scripts?
Convert document colors to Multichannel, Device Link, or Abstract color profiles (Photoshop)
Choose Edit > Convert To Profile.
Click Advanced. The following additional ICC profile types are available under Destination Space:
Multichannel Profiles that support more than four color channels. These are useful when printing with more than four inks.
Device Link Profiles that transform from one device color space to another, without using an intermediate color space in the process. These are useful when specific mappings of device values (like 100% black) are required.
Abstract Profiles that enable custom image effects. Abstract profiles can have LAB/XYZ values for both input and output values, which enables generation of a custom LUT to achieve the desired special effect.
Note: Gray, RGB, LAB, and CMYK color profiles are grouped by category in Advanced view. They are combined on the Profile menu in Basic view.
To preview the effects of the conversion in the document, select Preview.
Malcolm Mackenzie
Post by Malcolm Mackenzie »
I think you can it all using recorded action in PS which you can run from Switch.
I have tried action but the popup windows will show when running to convert to color with icc. So It will interrupt the action process.
Malcolm Mackenzie
Hi
Make sure in your PS action you have all dialogue boxes switched off.
Hi Dear Malcoim,
Appreciate your reply kindly. I have switch off the dialog box and the dialog window still pop-up.
