Get info from google sheets?
Hi. Is it possible to somehow pull data from google sheets regularly to switch as xml? I suppose I need scripting module for that? Or perhaps there's any other way without it? Any ideas? Thanks.
						Re: Get info from google sheets?
Try using Zapier make a Zap that transfers the file (CSV or Excel) by FTP/Mail and you can pick it up in Switch. Convert it with this app (https://www.enfocus.com/en/appstore/pro ... cel-to-xml) and then you can use all info in Switch.
							Working with: Enfocus Switch, Pitstop Server, Quite Imposing, Kodak Nexpress (max 640mm sheets and 500grs) with most options (HD, Clear, Gold, White, Light-Black and Matt fuser), Polar Mohr D80 (compucut), Multigraf, Heidelberg, GMP, Duplo, Hohner.
