embedded Metadata
flussidicaio
embedded Metadata
Post by flussidicaio »
Until Switch 2018 in the job ticket you could find the list of embedded metadata. Now you can't anymore.
does anyone know where the list went?
Re: embedded Metadata
Nothing has changed in Switch 2019 or Switch 2020 with respect to embedded metadata. The only thing is that there is no access to embedded metadata when using the Node.js scripting in Switch 2020.
flussidicaio
in the old job ticket file (.ijt) there was the "datasets" xml node containing the list of embedded datasets
<Datasets>
<DatasetEntry DatasetName="Submit" FileName="0Z6QL001.xml" Type="XML"/>
<DatasetEntry DatasetName="com.enfocus.PitStopServer.cli-config" FileName="0Z6QM000.xml" Type="XML"/>
<DatasetEntry DatasetName="com.enfocus.PitStopServer.cli-taskreport" FileName="0Z6QM001.xml" Type="XML"/>
<DatasetEntry DatasetName="Log" FileName="0Z6QM000.pdf" Type="Opaque"/>
<DatasetEntry DatasetName="Check" FileName="0Z6QM005.xml" Type="XML"/>
</Datasets>
so knowing the name of dataset you could find it in the Dataset folder
Now the datasets node was no longer in the job ticket and you can't know the name of embedded dataset
