loop xml nodes?
automation
loop xml nodes?
Post by automation »
I have this XML. How can I loop the XML and get all values in <code>?
<Orders>
	<Order>
		<Product>
			<Line_Id>1</Line_Id>
			<Product_Id>9831</Product_Id>
			<Name>Pontus</Name>
			<Qty>1</Qty>
			<code>AAAAA</code>
		</Product>
		<Product>
			<Line_Id>2</Line_Id>
			<Name>Pontus</Name>
			<Qty>1</Qty>
			<code>BBBBB</code>
		</Product>
	</Order>
</Orders>
My code. I get the first log from nodeList but not my second log "code".
var dataset = job.getDataset("Xml");
var xml = new Document(dataset.getPath());
var nodeList = xml.evalToNodes("/Orders/Order/Products/Product");
s.log(1, "Found: " + nodeList.length); //This works
for(var i = 1; i < nodeList.length + 1; i++){
	var node = nodeList.at(i);
	var code = node.getValue(); //This is not working
	s.log(1, code);
Expected result in log
AAAAA
BBBBB
I don't get any suggestions when I write a dot (.) after "node" and get the error getValue(); is not a function.
Re: loop xml nodes?
You have to run an XSLT with Saxonica that splits the XML in to one XML per node you want to use.
mkayyyy
Re: loop xml nodes?
Post by mkayyyy »
To get to the "code" nodes you need to use this Xpath expression:
/Orders/Order/Product/code
Then to loop through them your for loop needs to start from 0 and you need to use the getFirstChild() function to be able to get to the value of the node. See below code that loops through logs the "code" nodes:
var nodeList = xml.evalToNodes("/Orders/Order/Product/code");
for (var i = 0; i < nodeList.length; i++) {
	var code = node.getFirstChild().getValue(); //This is not working
	s.log(1, code);
automation
Re: loop xml nodes?
mkayyyy wrote: Wed Sep 09, 2020 11:00 am To get to the "code" nodes you need to use this Xpath expression:
	s.log(1, code);
Thanks it worked!
