File stuck in Folder before script
stdougal
Post by stdougal »
We made a script to update the current status of a job as the file passes through the various stages of a flow in Switch.
The script is working as expected and is updating all the various fields in our system.
However we have an issue:
Currently the file(s) are stuck in the connector folder before the script (there is no connections after the script!).
I would appreciate any help/suggestions?
Below is a rough idea of the script
if (setToken(job))
// start the operation
if( finished && theHTTP.finishedStatus == HTTP.Ok && theHTTP.statusCode == 200 )
//success - operation started
//Now get the ID from the response
//success - Got ID now finish operation
//success
return true;
else
//fail
job.fail( "Failed to stop" );
else
//fail
job.fail( "Failed to get id" );
else
//fail
job.fail( "Failed to start" );
else
job.fail( "Failed Token" );
job.sendToNull( job.getPath() );
Thank You
Re: File stuck in Folder before script
You need a job.sendToSingle for it to go out of the script.
stdougal
Post by stdougal »
Thank you for the quick reply
Do I need that if I don't want the file to continue on i.e. If I just want to trigger this script and have the file delete?
Is it possible to trigger a script without a PDF passing through it?
If you just want it to trigger you use the job.sendToNull that you have there.
But check with a s.log() that you really end up in that step.
stdougal
Post by stdougal »
That's Great
Thank you for your help
