Calculate time elapsed for job completion
PdFUser5000
Post by PdFUser5000 »
I am trying to calculate time elapsed for completing a job.I'm using Privatedata keys for this, but the answer comes out wrong. Is my formatting wrong?
JobStart=[Switch.Date:Format="hh-mm-ss",TimeZone="System"]
JobEnd=[Switch.Date:Format="hh-mm-ss",TimeZone="System"]
[Switch.Calculation:Expression="[Job.PrivateData:Key="JobEnd"]-[Job.PrivateData:Key="JobStart"]"]
09-36-29 - 09-34-05 gives an answer -104. The correct answer should be 144 (seconds).
I want this number to be shown in an email.
laurentd
Re: Calculate time elapsed for job completion
Post by laurentd »
You are subtracting a time from a time.
You should subtract an amount of seconds from an amount of seconds.
This works:
JobStart=[Switch.Calculation:Expression="[Switch.Date:Format="MM",TimeZone="System"] * 31 * 24 * 3600 + [Switch.Date:Format="dd",TimeZone="System"] * 24 * 3600 + [Switch.Date:Format="hh",TimeZone="System"] * 3600 + [Switch.Date:Format="mm",TimeZone="System"] * 60 + [Switch.Date:Format="ss",TimeZone="System"]"]
JobEnd=[Switch.Calculation:Expression="[Switch.Date:Format="MM",TimeZone="System"] * 31 * 24 * 3600 + [Switch.Date:Format="dd",TimeZone="System"] * 24 * 3600 + [Switch.Date:Format="hh",TimeZone="System"] * 3600 + [Switch.Date:Format="mm",TimeZone="System"] * 60 + [Switch.Date:Format="ss",TimeZone="System"]"]
[Switch.Calculation:Expression="[Job.PrivateData:Key="JobEnd"] - [Job.PrivateData:Key="JobStart"]"]
PdFUser5000
Thank you very much!
Just a small extra question, if i want to convert this to minutes and seconds, i use something like this?
for minutes:
[Switch.Calculation:Expression="((([Job.PrivateData:Key="PDFEnd"] - [Job.PrivateData:Key="PDFStart"])- (([Job.PrivateData:Key="PDFEnd"] - [Job.PrivateData:Key="PDFStart"])%60))/60)"]
for seconds:
[Switch.Calculation:Expression="(([Job.PrivateData:Key="PDFEnd"] - [Job.PrivateData:Key="PDFStart"])%60)"]
laurentd
Post by laurentd »
Add an extra folder where you define this private data (time in seconds):
JobTime=[Switch.Calculation:Expression="[Job.PrivateData:Key="JobEnd"] - [Job.PrivateData:Key="JobStart"]"]
Then to get the processing time in minutes and seconds, use this:
for minutes: [Switch.Calculation:Expression="( [Job.PrivateData:Key="JobTime"] - ( [Job.PrivateData:Key="JobTime"] % 60 ) ) / 60"] min
for seconds: [Switch.Calculation:Expression="[Job.PrivateData:Key="JobTime"] % 60"] sec
