String Replace
JimmyHartington
String Replace
Post by JimmyHartington »
Hi
I am trying to use the String Replace app https://www.enfocus.com/en/appstore/pro ... ng-replace to fix/cleanup the HTML of an e-mail received by Switch.
This is a part of the HTML
  <br><b>Send til:</b>
  <br>Skabertrang
  <br>Jimmy
  <br>Stagehøjvej 27a
  <br>Silkeborg,  8600
  <br>DK
  <br>
  <br><b>Papiromkostninger:  </b>kr. 0,00
  <br><b>Prepress-omkostninger:  </b>kr. 0,00
  <br><b>Trykkeomkostninger:  </b>kr. 0,00
  <br><b>Indbindingsomkostninger:  </b>kr. 0,00
  <br><b>Forsendelsesomkostninger:  </b>kr. 0,00
  <br>
  <br><b>PRODUKTLISTE</b>
  <br>
I am trying to remove the lines with:
Papiromskostninger:
Etc.
I also add a stylesheet at the start of the file.
This is my multiline value in your app.
</head>=</head><style>  @media print {  @page {  size: 297mm 420mm; margin: 10mm; }  body { margin: 10mm; }}</style>
.*?Papiromkostninger:.*?0,00=
The first line replaces fine.
But on the second line I try to use RegExp to remove the line with Papiromkostninger, but it does not work.
Is there some certain way I need to define the RegExp to get it to work?
JimmyHartington
Re: String Replace
I found the answer elsewhere on the forum viewtopic.php?f=13&t=3740&p=11542&hilit ... ext#p11542
So the greedy ? in RegExp is not supported in Switch.
But I the used the {3,180} to define a shorter amount of characters to look for.
