Using xml Pick tool to xml with rar binding. rar unpacked, you will get a folder, there will be pdf.
pdf How to get xml data inside.
- TOP CONTRIBUTOR
bx609311029 wrote: Using xml Pick tool to xml with rar binding. rar unpacked, you will get a folder, there will be pdf.
Does the XML data contain the path to the RAR archive?
Do you want to add the XML data to the RAR archive?
The situation is that an RAR is delivered containing a folder with several PDF's and an XML with the name of the RAR. The XML has to get attached to all PDF's. This is quite simple:
1: "XML pickup": this will attach the XML as a dataset to the RAR file.
2: "Uncompress": this will extract the contents of the RAR and will automatically attach the XML to the extracted content. In this case it is a folder.
3: "Dismantle job": this will take the individual files out of the job folder and turn them into jobs and again Switch will automatically attach the dataset to the new jobs.
