Can't delete top level folders created with Node
PdFUser5000
Post by PdFUser5000 »
I am trying to create a hierarchy with folders and add files inside them. But after creating the folders, i cant delete the top 2 levels of the folder hierarchy.
My hierarchy looks something like this
1st level: Folder 1 (Phoenix) Can't delete
2nd level: Folder 2 (modelName) Can't delete
3rd level: Folder 3 and Folder 4 ( PDF sizes and reports) Can delete these
Tried using 3 different functions, but the same problem still exists.
I Can delete the files with Node.
When trying to save to desktop, windows says the folder is no longer located ther, although it most certainly is.
const fs = require('fs-extra');
async function jobArrived(s, flowElement, job) {
    try {
 let tempPath = await job.get(AccessLevel.ReadWrite);  //file path
 //data from switch for functions
 let originalPath = await flowElement.getPropertyStringValue("OriginPath");
 // new location for creating extra folders
 let modelName = await flowElement.getPropertyStringValue("GetModelFolder");
 //folder name for creating folder modelName
 let fileName = await flowElement.getPropertyStringValue("GetFileName");
//file name
//create directories for files Phoenix folder + PDF sizes + Reports folder
async function CreateFLDRS (directory) {
    try {
      await fs.ensureDir(directory)
      await job.log(LogLevel.Info, "Folders created");
    } catch (err) {
      await job.log(LogLevel.Error, err.message);
 await CreateFLDRS(originalPath + "/Phoenix" +"/" + modelName + "/PDF sizes");
 await CreateFLDRS(originalPath + "/Phoenix" +"/" + modelName + "/Reports");
//move files to correct folder
let PDFloc = originalPath + "/Phoenix" +"/" + modelName + "/Reports" + "/" + fileName
async function MoveFile () {
  try {
    await fs.copy(tempPath,PDFloc)
  } catch (err) {
await MoveFile();
       await job.sendToSingle();
catch(e) {
    await job.log(LogLevel.Error, e.message);
Re: Can't delete top level folders created with Node
I have not tested it but I can only assume that fs.ensureDir creates the directories with a mode that does not allow them to be deleted. fs.ensureDir takes a second parameter that specifies the access mode. Try adding that with the octal value 777 (you may know that from the command chmod) which is written as 0777, not 777! That is decimal and will not give the expected result.
One thing puzzles me, though. You say you can't delete folders but your code does not try to delete anything?
PdFUser5000
freddyp wrote: Thu Feb 11, 2021 8:38 am I have not tested it but I can only assume that fs.ensureDir creates the directories with a mode that does not allow them to be deleted. fs.ensureDir takes a second parameter that specifies the access mode. Try adding that with the octal value 777 (you may know that from the command chmod) which is written as 0777, not 777! That is decimal and will not give the expected result.
I want the user to be able to delete this folder manually.
Ok so what was wrong, was that i had a whitespace between 2 variables, which somehow changed the 2 top folders to read only. is there any way i can insert a whitespace there at all ?
[Metadata.Text:Path="/orderinfo/model/designID",Dataset="PPinfo",Model="XML"](space was here)[Metadata.Text:Path="/orderinfo/model/suffiks",Dataset="PPinfo",Model="XML",Space="trim"]
