switchScriptTool --pack
stargazerllc
Post by stargazerllc »
Does anyone know the importance of packing up a node script using the switchScriptTool --pack vs just using the script folder?
patej
Re: switchScriptTool --pack
Post by patej »
It depends on how your environment is setup and what kind of things you do with the scripts, but one key thing is that using script folders is currently a bit slower than using packed scripts. There are some other reasons, too, and Enfocus has listed those on this page: https://www.enfocus.com/manuals/Develop ... cript.html
stargazerllc
thanks, I thought I looked all through that and didn't find a good list. I guess I missed it. That list looks like a good explanation.
foxpalace
Post by foxpalace »
remember - if you are using a Icon in that Script - the pack would only work, when the icon-name is the same as the script
borisCM
Post by borisCM »
switch is not accepting my packed script folders. anyone else had this problem?
am i doing something wrong?
SwitchScriptTool.exe --pack .
creates a .sscript file in the chosen folder, but switch does not accept it.
using switch 2020 fall
patej
Post by patej »
I think you should pack it outside the script folder so that it doesn't overwrite the "0 KB .sscript".
For example:
SwitchScriptTool.exe --pack . ../build/
to have it created inside a "build" directory at the same level as your script folder.
borisCM
Post by borisCM »
sorry,
that wasn't clear
i pack it to ../../PRD
so it is outside of the original folder
