PDFTK does not output PDFs in Switch unless manual folder scan is invoked
Arthur
Post by Arthur »
Hello clever heads :)
I am experiencing an annoying issue with PDFTK server, which seems it does not output PDFs to a folder of choice, unless I go Scan Folders Now manually from the right-click in Switch.
Until then, no PDF is produced.....
Anyone had anything like that ??
The command is fairly simple:
"%1" output "final_location\folder\_[Job.UniqueNamePrefix]_[Job.Name]"
Help anyone please ?? :)
PDFTK Issue.PNG (28.99 KiB) Viewed 8114 times
laurentd
Re: PDFTK does not output PDFs in Switch unless manual folder scan is invoked
Post by laurentd »
You should use "%2" with output "File at Path"
And also set the Output property to "File at path" it is by default None and will there fore not output anything
Arthur
Post by Arthur »
Will check that later. I chose a defined path however as the "%2" never worked for me....
Will report after the changes.
Interesting though....
Arthur wrote: Mon Apr 12, 2021 3:06 pm Will check that later. I chose a defined path however as the "%2" never worked for me....
Sounds like the Output property is set to None
Arthur
Post by Arthur »
I shall report that the suggested amendments did the job and indeed it works as expected.
Which on the other hand I am finding strange, since we've been using PDFTK in our flows for the last 3 years and it never worked with "%2" for the output, yet it always did with a fixed path, as exampled earlier.
Now on the new machine it works using "%1" output "%2" and file at path and this is the most important bit.
Thank you for your help, as I would probably have my mind fixed on how it used to work for the last couple of years and be going in circles trying to figure it out myself.
Thx again.
