Running a Windows *.bat-file in Switch 2018? Where can I find "Execute Command"?
automation
Post by automation »
We use Switch 2018 and I want to run a Windows *.bat-file. I have read that many recommend "Execute Command". However, I can not find it in Switch among the tools and not when I seach in Enfocus Appstore.
laurentd
Re: Running a Windows *.bat-file in Switch 2018? Where can I find "Execute Command"?
Post by laurentd »
In Switch 2018, you need the Configurator Module to use Execute Command.
Execute Command is now part of the Switch Core Engine since Switch 2019 Fall.
automation
laurentd wrote: Thu Apr 29, 2021 1:39 pm In Switch 2018, you need the Configurator Module to use Execute Command.
Is "Configurator Module" part of Switch 2018 or in appstore? Can't find it when I search in in Switch.
laurentd
Post by laurentd »
Switch is modular. On top of the Switch Core Engine, you can add different modules.
https://www.enfocus.com/manuals/UserGui ... intro.html
You need an extra license for these extra modules and features.
Or you can upgrade to Switch 2020 (and very soon 2021).
If you have a Switch Maintenance, the updates are included.
