setting up XPath Loop expression in XML Repeater
Posted: Thu Jul 22, 2021 5:28 am
I have been trying to split Group XML into individual XML files using XML Repeater. But I'm unable to set up XPath loop expression properties. I tried, it's not splitting into individual XML files. Could you please guide me to set up Xpath loop expression? Below is my XML.
<csv entries="1224">
<entry num="1">
<Name>Job_0001</Name>
<TrimHeight>6.85</TrimHeight>
<TrimWidth>9.75</TrimWidth>
<Copies>6</Copies>
<Material>Foamboard</Material>
<Thickness>0.2in</Thickness>
<Bleed>0</Bleed>
<PDF_Path>D:\DATA\ImpFlow_US\LFP\Gang_FB_Rect_CSV2_1224\6.85x9.75.pdf</PDF_Path>
</entry>
<entry num="2">
<Name>Job_0002</Name>
<Copies>5</Copies>
<Bleed>0</Bleed>
</entry>
<entry num="3">
<Name>Job_0003</Name>
<Copies>11</Copies>
<Bleed>0</Bleed>
</entry>
<entry num="4">
<Name>Job_0004</Name>
<Copies>5</Copies>
<Bleed>0</Bleed>
</entry>
</csv>
<entry num="1">
<Copies>6</Copies>
<Bleed>0</Bleed>
</entry>
<entry num="2">
<Copies>5</Copies>
<Bleed>0</Bleed>
</entry>
<entry num="3">
<Copies>11</Copies>
<Bleed>0</Bleed>
</entry>
<entry num="4">
<Copies>5</Copies>
<Bleed>0</Bleed>
</entry>
</csv>
