setting up XPath Loop expression in XML Repeater
Aar096
Post by Aar096 »
I have been trying to split Group XML into individual XML files using XML Repeater. But I'm unable to set up XPath loop expression properties. I tried, it's not splitting into individual XML files. Could you please guide me to set up Xpath loop expression? Below is my XML.
<csv entries="1224">
<entry num="1">
<Name>Job_0001</Name>
<TrimHeight>6.85</TrimHeight>
<TrimWidth>9.75</TrimWidth>
<Copies>6</Copies>
<Material>Foamboard</Material>
<Thickness>0.2in</Thickness>
<Bleed>0</Bleed>
<PDF_Path>D:\DATA\ImpFlow_US\LFP\Gang_FB_Rect_CSV2_1224\6.85x9.75.pdf</PDF_Path>
</entry>
<entry num="2">
<Name>Job_0002</Name>
<Copies>5</Copies>
<Bleed>0</Bleed>
</entry>
<entry num="3">
<Name>Job_0003</Name>
<Copies>11</Copies>
<Bleed>0</Bleed>
</entry>
<entry num="4">
<Name>Job_0004</Name>
<Copies>5</Copies>
<Bleed>0</Bleed>
</entry>
</csv>
rzacherl
Re: setting up XPath Loop expression
Post by rzacherl »
Hello unknown XML Repeater user,
the loop XPath expression needed to split this XML file into separate entry entities should simply be
/csv/entry
If it doesn't work, please contact me again.
Best regards,
Robert
Aar096
Post by Aar096 »
Hello Robert,
Thank you for your reply.
I tried it, but my file is disappearing in messages it is showing "IJT could not be opened: '000GZ.ijt'", attached my flow & XML repeater screenshot. Kindly help.
rzacherl
Re: setting up XPath Loop expression in XML Repeater
Post by rzacherl »
Hello Aar096,
please send me your flow and a CSV file (or at least the XML file which comes out of CSV2XML).
Just out of personal interest: why don't you output single XML files for each CSV record from within CSV2XML? Alle you have to do is to switch the script property Output as single XML file from Yes to No.
