select specific pages and remove
Urraco
Post by Urraco »
I want to select a single pages, ex. page 4 and remove spot color from that page.
Can be done with an action without selecting page range every time?
Re: select specific pages and remove
If you're working interactively in PitStop Pro you can go to the page you want to process and in the processing panel before you click the big Run button change the dropdown from "Complete document" to "Current page".
With that dropdown you can even run Action Lists on only the objects you selected.
Urraco
Post by Urraco »
no,
is it possible to run an action only on a certain page?
without using the "Run on" panel
Post by abailescollins »
Only if you have a select action for the pages in the Action List.
Bear in mind that can be variable, so you can enter new values each time you run the Action List
