select specific pages and remove
Posted: Mon Aug 02, 2021 3:58 pm
by Urraco
I want to select a single pages, ex. page 4 and remove spot color from that page.
Can be done with an action without selecting page range every time?
Re: select specific pages and remove
Posted: Wed Aug 11, 2021 2:36 pm
by bens
If you're working interactively in PitStop Pro you can go to the page you want to process and in the processing panel before you click the big Run button change the dropdown from "Complete document" to "Current page".
With that dropdown you can even run Action Lists on only the objects you selected.
Posted: Fri Aug 13, 2021 3:37 pm
by Urraco
no,
is it possible to run an action only on a certain page?
without using the "Run on" panel
Posted: Wed Aug 18, 2021 2:46 pm
by abailescollins
Only if you have a select action for the pages in the Action List.
Bear in mind that can be variable, so you can enter new values each time you run the Action List
