SwitchScriptExecutor 50000 script entry points
PdFUser5000
Post by PdFUser5000 »
In my console i get the following notification:
SwitchScriptExecutor process with ID 10692 has been stopped because it executed 50000 script entry points. Processing is not affected: a new SwitchScriptExecutor process will be started when necessary.
Is this something i should be worried about? 50000 seems a lot. Could there be an error somewhere in my flow?
Re: SwitchScriptExecutor 50000 script entry points
This is perfectly normal.
The script executor might have been doing different tasks from different flow elements since the moment you started switch. that's how you can get 50000 entry points.
