Various pages have a green box. Which I can select. And I can select that entire page.
But I want to select the "next page" and rotate it.
So: All pages with a green box go to next page and rotate page 90º
Thanks in advance!
Select NEXT Page
Re: Select NEXT Page
The only way I currently see to do this would be in two steps, using Switch automation to connect the dots. First log all the pages with a green box and create an xml report. Read that report to get the page numbers of those pages, add 1, and use the result in a variable set to select the pages you want.
It's a bit of a process but I can't think of a way to do it only in PitStop sorry.
CruzinCooler
Can you explain how you got it to choose the page with the green box?johnfrancis wrote: ↑Thu Sep 16, 2021 5:49 pm Various pages have a green box. Which I can select. And I can select that entire page.
Thanks in advance!
