Adjusting Crop Box Size
stome
Post by stome »
Hi All,
Is there an action to set the Crop Box to be 0.5 inch larger than the Trim Box?
Kind regards!
john.dean@esko.com
Re: Adjusting Crop Box Size
Post by john.dean@esko.com »
Greetings,
This Action List requires a Trim box to be defined before running it. So, if your PDF has a trim and you need to make the Bleed, Crop, and Media boxes 0.5 inches larger than Trim, this will do it regardless of the original trim box size. Make any edits that you need to it.
Let me know if it works.
Set Crop Box 0.5 Over Trim.zip
Unzip and import
(1.79 KiB) Downloaded 877 times
stome
Post by stome »
Thank you so much! It works perfectly!
