Writing out to a basic text file
w.bromley
Post by w.bromley »
Hi Guys!!
I have a simple flow which splits out PDFs depending on the width of the artwork. If it's over a certain width, it becomes "oversized" and the height of the artwork needs to be recorded. Currently I have it all set up fine, except the last stage which is to make a record of the height, which I currently just have coming out of the flow in an email...
Anyone got any ideas how I can just append the variable to the end of a basic text file or something? Some way that I can collect all the info in some central place that I can then read it out of?
Thanks in advance for any ideas!!
Re: Writing out to a basic text file
There is an app for that
https://www.enfocus.com/en/appstore/pro ... m-template
Read the documentation, it will explain how to do it.
w.bromley
Post by w.bromley »
Fantastic - thanks so much! I did take a look at the apps but couldn't really see anything that did the trick... Ill have a play with this!!!
