Run at scheduled time
mlongo
Post by mlongo »
I realize there is a Hold Job tool that I can leverage to have a flow run for example every 2 hours. But is there a scheduler tool or something similar to allow me to setup a flow to run at say every Mon, Wed and Fri at 8am and 1pm? Or maybe every day at specifically 6am and 6pm?
Thanks!
Re: Run at scheduled time
On the Hold job configurator you can set that on the outgoing connection. You can have several connections from one hold job..
Look here:
https://www.enfocus.com/manuals/UserGui ... d_job.html
mlongo
Post by mlongo »
jan_suhr wrote: Fri Dec 03, 2021 6:25 pm On the Hold job configurator you can set that on the outgoing connection. You can have several connections from one hold job..
Look here:
Perfect! Thank you!
And there is also "Inject job": on the outgoing connection you can also trigger the creation of a dummy job at a certain time. When used in such a case you can leave out the incoming connection.
