Split PDF Files in main.js
congomonster
Post by congomonster »
i'm just trying out the "new" way to code with NodeJS. Is there a way to split a pdf file in Javascript? The documentation gives me a PDF Class:
http://www.enfocus.com/manuals/Develope ... class.html
And i was able to build a little flow which outputs the filename and the pagenumber of the pdf-file to the messages website. Now i was wondering how can i split them in seperate files. For example the pdf has 12 sites then i would split 1, 2, 11, 12 in a seperate file. How can i achieve that?
Re: Split PDF Files in main.js
Have you tried https://www.enfocus.com/en/appstore/pro ... -pdf-pages?
If your use case is not covered, give more details about how the file should be split and preferably also provide a sample file.
tdeschamps
Post by tdeschamps »
Hi Congomonster,
We are actually developping and beta-testing with some of our customer an app for this purpose. Stay tuned in early january!
There is an app for that
https://www.enfocus.com/en/appstore/product/uncover-pdf
It will just do what you want. It will require PDF Toolkit.
