EMFILE: too many open files
borisCM
Post by borisCM »
i think i am doing something wrong in my node.js projects.
after a while i get a lot of
"EMFILE: too many open files, open" errors in switch
i'm working on windows
i am using tmp module to create the tmp files
const tmp = import("tmp")
let orderXMLdocTMP = (await tmp).fileSync();
and fs to delete them when i'm done with the file.
try {
      (await fs).unlinkSync(orderXMLdocTMP.name); //delete temp file
      await job.log(LogLevel.Info, `unlinkSync ${orderXMLdocTMP.name} succes`);
    } catch (err) {
      await job.log(LogLevel.Error, err);
i don't get any errors back. but the file is not deleted in the temp folder.
so after a day i have a 1000 temp files in that folder. and when i try to open them they all have "access denied".
can anyone help?
what am i doing wrong?
Re: EMFILE: too many open files
There is no need to use await with the synchronous methods of tmp.
Check the user access rights of the file that were created. If they are not OK, I suggest you try adding an access mode at the moment of creating the temporary file:
let orderXMLdocTMP = tmp.fileSync( { mode: 0o777 } );
The documentation of tmp uses this variant as well. I do not know if both work or not:
let orderXMLdocTMP = tmp.fileSync( { mode: 0777 } );
777 means read/write/execute for everybody.You can find more info here: https://en.wikipedia.org/wiki/File-system_permissions
borisCM
Post by borisCM »
thanks for the quick response.
the await gets added automatically while typing and if i dont place it, visual studio code gives a type error.
Property 'fileSync' does not exist on type 'Promise<{ default: typeof import(.../DEV/ImpPPXML/node_modules/@types/tmp/index"); file(options: FileOptions, cb: FileCallback): void; file(cb: FileCallback): void; ... 6 more ...; tmpdir: string; }>'.ts(2339)
main.ts(1115, 34): Did you forget to use 'await'?
i also can't transpile without the (await tmp)
Info: The script package from the folder 'C:/Users/switch/Dropbox/Switch/BackupSwitch/Scripts-XSLT/NodeJS/DEV/ImpPPXML' is packing
Error: Failed to transpile the code: TypeScript failed with exit code 2
Error: TypeScript standard output: ../../../../../../../AppData/Local/Temp/2/ImpPPXMLMvZEUq/ImpPPXML/main.ts(1284,30): error TS2339: Property 'fileSync' does not exist on type 'Promise<{ default: typeof import(/AppData/Local/Temp/2/ImpPPXMLMvZEUq/ImpPPXML/node_modules/@types/tmp/index"); file(options: FileOptionsDiscardFd, cb: FileCallbackNoFd): void; file(options: FileOptions, cb: FileCallback): void; file(cb: FileCallback): void; ... 6 more ...; tmpdir: string; }>'.
Error: Failed to encrypt the script package 'C:/Users/switch/AppData/Local/Temp/2/ImpPPXMLMvZEUq/ImpPPXML'
ps:
changing the mode Oo777 does not help. will get in touch with our IT partner.
i would expext a fs.unlinksync err when deleting is not possible?
Did you add the typings for tmp?
npm i @types/tmp --save-dev
borisCM
Post by borisCM »
jes jes.
the standard fs has the same behavior and there i don't need to install the types separatly normally
i need to add it like this:
(await fs).writeFileSync(tmpBoundCover.name, xmlStringBoundCover, "utf-8");
(await fs).unlinkSync(tmpBoundCover.name);
borisCM
Post by borisCM »
this fixed the type issue
import *  as fs from "fs";
import * as tmp from "tmp";
instead of
const fs = import("fs");
borisCM
Post by borisCM »
think i found a solution
https://raszi.github.io/node-tmp/
const tmp = require('tmp');
const tmpobj = tmp.fileSync();
console.log('File: ', tmpobj.name);
console.log('Filedescriptor: ', tmpobj.fd);
// If we don't need the file anymore we could manually call the removeCallback
// But that is not necessary if we didn't pass the keep option because the library
// will clean after itself.
tmpobj.removeCallback();
