Compare page count and route job accordingly
popniete
Post by popniete »
Hi
I'm failing on a problem I thaught would be simple: I want to route a jobfolder to folder A, if all contained PDFs have the same page count. If not, route job to folder B. Any hints on this? Thanks!
laurentd
Re: Compare page count and route job accordingly
Post by laurentd »
Here is a flow to solve this:
• First ungroup the job and write the number of pages of each file in a private data, "pages".
• Assemble the job with metadata merge, the "pages" private data will be the one of one of the files in the job.
• Ungroup the job again, and check if the number of pages of each file equals the "pages" private data.
• If not, add a "pageCount" private data with value "different".
• Then assemble the job again with metadata merge.
• Sort the jobs based on that "pageCount" private data.
sort jobs with different page count.png (19.83 KiB) Viewed 5282 times
sort jobs with different page count.sflow.zip
(15.11 KiB) Downloaded 717 times
I am interested in knowing a bit more about the use case. Why do the number of pages have to be the same? How many files can there be inside the job folder? How many pages can there be?
popniete
Post by popniete »
Hi Laurent, thank you so much, this does exactly what I need!
Tobi
