Set a future date in javasscript to use in HTML template
JimmyHartington
Post by JimmyHartington »
Hi
I have a flow, where I send a link to a pdf via email.
This pdf-file is automatically deleted after 14 days.
Currently in the email I write that the file is available in 14 days.
What I would like is to write to which date the file is available.
I have this JavaScript, which calculates the future data.
var targetDate = new Date();
targetDate.setDate(targetDate.getDate() + 14);
var dd = targetDate.getDate();
var mm = targetDate.getMonth() + 1; // 0 is January, so we must add 1
var yyyy = targetDate.getFullYear();
var dateString = dd + "/" + mm + "/" + yyyy;
return dateString
And have tried to set this script on the JobState, so I can pull in the jobstate into the HTML-template for the email.
But JobState stays blank.
Is there somehow I can set a metadate element for the file instead using the script executor?
If you want to store little pieces of information about a job the best approach is to put them in private data. You can find the explanation of the getPrivateData and setPrivateData methods in the Job class.
