Channel Closed issue
borisCM
Post by borisCM »
hi,
Once in a while i get a "Channel closed" error in some of my nodeJS scripts.
i had 2 this morning in 2 different scripts with 2 different jobs.
when processing the exact same jobs with the scripts again, no issues.
i have no idea where to start looking.
is this the result of bad programming?
if anyone else had this issue or could point me in the right direction to start looking?
running switch on windows server 2016
Re: Channel Closed issue
I would suggest you contact Enfocus Support on this one. They most likely need your full Switch messages, scripts that had the issue and your Switch version.
borisCM
Post by borisCM »
ok,
thanks for your reply, will do that
kind regards
borisCM
Post by borisCM »
according to enfocus support this is a bug.
and hopefully fixed in the spring release.
Yes, if possible, the fixed is planned to be in the v2022/Spring release. Of course, this could change if the fix becomes more complicated or due to other priorities.
