How to save parent folder name as variable?
zurek
Post by zurek »
Hi guys,
I'm pretty new to Switch and will appreciate your help here:)
I'm looking for a way to save original file's directory as variable (name of the folder the IN file comes from). Is there a possibility to do this?
Re: How to save parent folder name as variable?
You have to install the SwitchHelper application on the client and define in the submit point that it requires the use of SwitchHelper: https://www.enfocus.com/en/support/down ... tch-helper
When you do that the variable [Job.Origin] will have the path to the original location of the file. With Before, After and Search you should then be able to extract the part that you want.
Important note: you must browse to the file from the submit point! Do NOT use drag&drop! If you use drag&drop the browser will not give access to the path of the file that was dropped and [Job.Origin] will still be empty even if you took care to use SwitchHelper.
zurek
Post by zurek »
Thanks for the help Freddy. I didn't know that SwitchHelper allows that.
Shame that drag&drop functionallity isn't available here, I'll have to look for some walk around solution then.
