XSLT version on Switch
joaodaffonsojr
Post by joaodaffonsojr »
Hello !
I´m trying to split a XML using XSLT.
But as I researched it´s only possible if XSLT version 2.0 is avaible.
As far as I know Switch still version 1.0 is that correct ?
Re: XSLT version on Switch
You have to use the Saxonica configurator. It needs you to download the Saxonica program, after that you can do any XSLT 2 in Switch.
joaodaffonsojr
jan_suhr wrote: Tue Jun 07, 2022 3:15 pm You have to use the Saxonica configurator. It needs you to download the Saxonica program, after that you can do any XSLT 2 in Switch.
Thanks Jan ! I´ll give a try.
joaodaffonsojr
Thanks Jan !
It worked very ... very fine !
