approved PDF with email
jena@stibo.com
Post by jena@stibo.com »
Hi
I hope someone can help me, I haven a folder where there a many PDF in, put I can only print the PDFs, there are approved a the customer.
I get a mail, from our customer there tells, now are this PDF approved, and now can I Print it, In the subject in the mail, here are the order number of witch PDF there should be printed.
So I haven lots of PDF, but shall only printet the PDF there are approved, the PDF there are approved.
Shall I use "Hold Jobs" or are it better to use "Inject job"
Jens Andersen
Re: approved PDF with email
In the variables in the Group "Email" you can use "Subject" and from there get the Ordernumber. Then you can pickup the file with that order number with Inject job and send it to print.
But a better solution would be to use PDF Review module
jena@stibo.com
Thanks Jan
Yep, its works its was very simple. I could just fine how I should start, but its works now.
Jens
