Find all instances where "flow stage" is used
nna
Post by nna »
Hi all
Since the ability to set a flow stage on a folder has been "discontinued" in Spring 2022: Is there a way to quickly find instances where a value has been set in "Flow stage"? I have a customer who uses the client module and has hundreds of folders in their flows. And I'd like to find every "Flow stage" instance without having to select every folder in every flow. Thank you in advance!
Re: Find all instances where "flow stage" is used
Every flow is an XML-file, you should be able to search them for that.
laurentd
Post by laurentd »
You can also document your flows.
It will create an html document of each flow.
In there you can also easily look for the flow stages.
