pdf to ai
Krzysztof Mycek
pdf to ai
Post by Krzysztof Mycek »
Does anyone know any server application that converts pdf files to ai in switch?
Re: pdf to ai
You can use Adobe Illustrator in Switch and save to different versions of .ai
In some cases you need a script to run in Ai to do it. Don't need Scripting module for that.
Krzysztof Mycek
Re: pdf to ai
Thank You Jan, but Illustrator isn't server apps and should be problem when describe some dialog window ...
I need to move the layer form pdf to the ai file but ... i see that is impossible I hope ....
Re: pdf to ai
No problem to use a single Illustrator on your Switch server. I have flows that save back to Ai-files version 8 for some older system. You can turn off all dialog boxes for the process.
Eightyk
Re: pdf to ai
Post by Eightyk »
PDF and AI are interchangeable without third party apps. The only thing you need to do is use the rename app to change the extension from .pdf to .ai and vice versa.
