Alpha fill less than 100%
prepressscott
Post by prepressscott »
Hi, does anyone know of a way to check for fills of 0% of all 4 colours and an Alpha fill of less than 100%.
Thanks in advance
Scott
Re: Alpha fill less than 100%
There is an Action called "Check for zero fill line art".
There is an Action called "Select transparent objects" (only check the "Check fill alpha" checkbox) and add "Log selection" with an appropriate message. Objects with 100% alpha will be ignored.
prepressscott
Thanks for the info Freddy, unfortunately it fails to identify the offending box. Not sure what is going on but it isn't acting like a normal vector as it is invisible but when ripped appears as a grey box. For some reason I can't upload any pics here to show what is going on. Here are some links.
https://pasteboard.co/MHnY9k2J7sbg.jpg
https://pasteboard.co/uxLYcy8BACNk.jpg
https://pasteboard.co/A93GGwT4qowU.jpg
JimmyHartington
Post by JimmyHartington »
Is it possible to share the offending file/page as pdf?
prepressscott
Try this link
http://mbf.co/ycQaI9
yosimo
Post by yosimo »
Here I have knitted a quick and dirty solution.
Maybe it helps.
When executing the action list, make sure that the show results option is enabled so that the messages appear.
Action list for testing: https://magentacloud.de/s/HjMztnXrT6GKCMg
yosimo
PitStop User
prepressscott
Hi Yosimo, sorry for the late reply, I've been on annual leave. Happy to say that your action list works perfectly. I will incorporate it into my preflight and hopefully avoid this issue arising again. Many thanks!!
