How to change work folder Enfocus Switch
diguimfodera
Post by diguimfodera »
Hi, my Switch was installed on C:\drive and work folders (baking folder) was on f:\EnfocusSwitch
My server has a problem and f:\ drive lost all the data.
When the server was reinstalled the work folder from Enfocus Switch now is on c:\ drive in appdata.
How to I get change this backing folder for another destination (f:\ drive)?
Thank you!
My version: Enfocus Switch 2018
laurentd
Re: How to change work folder Enfocus Switch
Post by laurentd »
You have to stop Switch Server and use the SwitchDataRootMove tool (renamed ApplicationDataRootTool with more recent versions of Switch).
More info here.
In your Enfocus Switch program folder, should be: C:\Program Files\Enfocus\Enfocus Switch you'll find the ApplicationDataRootTool.exe it will fix it for you.
You have to turn the Switch server off before you use this tool.
diguimfodera
Wow, so easy. Thank you!
