Inject Wildcard moves job to problem jobs, instead of error connection
Posted: Tue Aug 09, 2022 2:19 pm
When my job repository field is wrong, the jobs is moved to problem jobs, instead of the error connection. Is this correct? Sometimes the repository is wrong in the data and I would like to send an email with the error. But since the job is moved to problem jobs, I have to add the send email element there and not in the flow.
example:
Dynamic property 'jobRepository' has invalid value 'T:\2000182 WLD Agency s.?r.l'
Job '_0U9Y3_B4010--DO0008385.xml' was moved from folder 'D:/Switch data root/backing/sampleflow/automanaged/Folder 24 (Copy)' to the problem jobs folder. Reason: see previous log message(s)
example:
