PageWidth how to assign a value to a variable?
menglv
Post by menglv »
How to use PageWidth variable in JavaScript?
var pageWidth = job.getVariableAsNumber("[Stats.PageWidth]");
menglv
Post by menglv »
Really worked, thank you very much.
menglv
Post by menglv »
var re =job.getPath();
re=re.mid(0,re.findRev("/")) + "/"+job.getName();
var curFileStats = new FileStatistics(re);
currentbook = curFileStats.getNumber("PageWidth");
why can't work?
Post by dkelly »
Is your job a file or folder?
menglv
Post by menglv »
dkelly wrote: Is your job a file or folder?
my job is a file.
menglv
Post by menglv »
how to use function FileStatistics?
Post by dkelly »
If your job is a single file use:
var curFileStats = new FileStatistics(job.getPath());
menglv
Post by menglv »
dkelly wrote: If your job is a single file use:
I tried, but without success.
Can you give me an example of flow?
test.sflow
Post by dkelly »
Your script doesn't follow the example I gave. You are not using the FileStatistics variable curFileStats to retrieve the PageHeight.
menglv
Post by menglv »
dkelly wrote: Your script doesn't follow the example I gave. You are not using the FileStatistics variable curFileStats to retrieve the PageHeight.
return value:undefined
menglv
Post by menglv »
Does anyone know what is the reason?
The return value of a script expression is the "last" variable on a line of its own.
var result = "1";
result;
If the script expression is more than just one or two lines I recommend to structure it as follows: create a function that returns a value and call that function on the last line of your script expression. You do not have to do it like this, but it is generically applicable.
function someFunction(par1, par2)
var returnValue;
//perform stuff that gives returnValue the correct value
return returnValue;
someFunction("first parameter",second_parameter);
menglv
Post by menglv »
freddyp wrote: Freddy
Theresult of this variable is not important, the key is currentbook which returned the result is undefined. I want this currentbook value equals pdf's PageHeight.
Then just write
currentbook;
as the last line of your script expression. I thought that was clear from the explanation.
