Select and log cut path length in millimeters
magnussandstrom
Post by magnussandstrom »
Hi, is it possible to log the length of a selected path as millimeters?
I tried the 'Check maximum path length' action, but I did not understand how to use it..
r.zegwaard
Re: Select and log cut path length in millimeters
Post by r.zegwaard »
Hi Magnus,
Attached is an actionlist that i once received from Enfocus.
It uses checks if the dieline is less than 1mm.
If not, then it logs a warning containing the actual length.
Robert
Line art length of spot color.zip
(2.68 KiB) Downloaded 1139 times
tdeschampsBluewest
Post by tdeschampsBluewest »
Hi Magnus,
Here is my two script i use for Zund purpose.
The first one will check the total length line of specific spot colors.
The second one will count the number of element of specific spot colors.
Zund.zip
(12.35 KiB) Downloaded 1550 times
magnussandstrom
Thanks, this works very good!
I also noticed that Pitstop ships with standard Action lists named 'Length of cutter guide...' :lol:
jasonx
Post by jasonx »
The standard action lists seem to select any object with the spot colour. Not only the spot color assigned to the stroke which is required by most imposition software. So they need to be adjusted.
