hi ,
I have a csv file as job and by reading this file I am navigating to local directory .I need to rename the files based on content of csv file .
I am using switch scripter for reading the csv file .
Is there any option to rename the file on local disk using switch javascript.
Rename file in local directory
- TOP CONTRIBUTOR
Switch only has copy() and remove() functions. You could use the system() function to call OS move/mv command.
var oldName = job.getPath();
var newName = job.createPathWithName("NewName");
s.copy(oldName, newName);
File.remove(oldName);
pradeepnitp
HI ,
This is not working as the file that I want to rename is not a input job . I need to rename a file which is placed in local drive and not comming from job.
What I tried is
var fbxCompletePath = "E:Pradeeptest.fbx" ;
var newJob = s.createNewJob(fbxCompletePath);
var oldFileName = newJob.getPath();
var newName = E:Pradeepsuccess.fbx ;
var newFileName = job.createPathWithName(newName);
s.copy(oldFileName , newFileName);
but this is not working .
Please help
What I tried is
Please help
- TOP CONTRIBUTOR
If you just want to copy a file somewhere
s.copy("E:Pradeeptest.fbx", "E:Pradeepsuccess.fbx");
To move it
File.remove("E:Pradeeptest.fbx");
A backslash in a string needs to be quoted.
To move it
pradeepnitp
Thanks . It's working .
