Replace PDF multipages by split files in same place
ChritianK
Post by ChritianK »
I made a flow to split PDF , and I want the split files at the same place than the original files, for now, the split files are created in a folder inside the folder where the original file is. Can you think is it possible ?
Regards,
Christian
JimmyHartington
Re: Replace PDF multipages by split files in same place
Post by JimmyHartington »
After the pdf-file has been split, you need to insert the "Ungroup Job".
