tiling in pitstop pro
Robbie
Post by Robbie »
Is there a tiling option in pitstop pro?
Re: tiling in pitstop pro
Here is an example of how this can be achieved. The zip file contains a PDF file of 200mmx200mm and the Action List cuts it into four pieces. There are several additional things you can still add: remove objects outside the crop box, clip objects, foresee overlaps, ... but you have a basis to start from.
Tiling example.zip
(5.87 KiB) Downloaded 510 times
