Extending Bleed
drcpub
Extending Bleed
Post by drcpub »
Saw the Enfocus video showing bleed extended on an angle, I have yet to be able to reproduce that. Has anyone found the bleed actions to be of use when they are not extended or mirrored, but rather extended on the angle? Have tried many different settings and no luck.
Re: Extending Bleed
There is an "Add bleed" action and an "Add bleed around contour" action. You have to use the latter. It has an option to use the trim box as the contour.
