Spot color picker
drcpub
Spot color picker
Post by drcpub »
Spot color picker is not showing the color previews at all, either in the supplied pantone colors or spot colors that are created. I replicate on another computer and it works fine, as it always has, But on a different computer, running same acrobat and pitsop 2022, the preview are omitted.
Any thouights?
Re: Spot color picker
There might be a problem with your colour management settings - for example a corrupt ICC profile. Try turning colour management off completely, or using the same settings as Acrobat.
drcpub
Post by drcpub »
I'm sorry, but I do not see a place to turn off color management completely, just place to change settings. Is that native to pitstop server? I have the stand alone plugin
There should be a preset called "Color management switched off" which you can apply. Or, in the settings editor, disable the checkbox "Enable color management". Be sure to check the PitStop Pro settings, not Acrobat.
