add bleed round contour image
Robbie
Post by Robbie »
I want to great extra bleed around a cutcontour. but can not get it to work with the action that available in pitstop. maybe there is something wrong with the PDF file, but can not find it.
TVR Sticker deur 35x35_1.pdf.zip
(30.06 KiB) Downloaded 594 times
Re: add bleed round contour image
You may want to "define" what path is actually your contour. Once you first select path (by color), adding bleed around contour is fine:
Result:
JimmyHartington
Post by JimmyHartington »
You need to add the name of your contour colour to the action:
Then it works (you just need to extend the media box at the bottom as well):
JimmyHartington
loicaigon was the fastest today :D
Robbie
Post by Robbie »
:D :D
Better two answers than none ;)
