help removing layers
anon69
Post by anon69 »
hello, i have a problem with a few pdfs. i have many magazines that are watermarked with an annoying website logo that i want to remove. i usually do it manually by deleting layers but some magazines are over 100+ pages. i would like to know if there is a faster way to accomplish this task without removing any wanted material. i have included a picture and a sample. thanks in advance.
file: http://dropcanvas.com/u8462
Post by dkelly »
This content is not on a layer. There are no layers in this file.
Instead it is normal text (WorldMags.net) added to the page to function like a watermark. You need a tool that can search and replace text to remove it.
Dwight Kelly
Apago, Inc.
When the text is also the same size (44pt) and when it is always in the same color (50.19% RGB) it is easy to select and remove it with a PitStop Action List.
Select by point size
Select color
AND
Remove selection
And there is also an action "Select by key phrase" with which you can select a specific piece of text.
There is more than one option.
