Hold file till flow is empty
b.schuring
Post by b.schuring »
Hi all,
Hope there is someone to help me.
I've got a flow where I split a PDF, hold all the pages en want to release them 1 by 1 but one if the first while is trought a certain part of my flow.
So after the first file is passed a specific folder in the flow I want to release the next, and so on...
Is this possible?
Thanks in advanced!
Bas
Re: Hold file till flow is empty
You can send the file waiting in an end folder of the flow, with a path to the disc. Then use the Inject tool to pick it up where you need to insert it again.
laurentd
Post by laurentd »
Hi Bas,
1. You can use the hold element, and on the outgoing connection, use the space jobs apart property.
2. You can use the Job sorter and spacer app, part of the Folder apps bundle.
Job sorter and spacer.png (30.92 KiB) Viewed 5091 times
Both methods work fine, but you have to estimate the time it takes to process a job.
And sometimes Switch will wait too long if a job is processed faster.
So here is solution 3, a bit like Jan's answer:
Send a copy of the job to a hold folder.
Use a hold element with space jobs apart property and folder constraint upfront, as illustrated.
At the end of the flow, inject that job from the hold folder, so that the next job can start.
This acts as a gatekeeper.
If you want the files to be processed in a certain order (e.g. alphabetically), replace Ungroup Job with the Job sorter and spacer app.
one job at a time.png (29.09 KiB) Viewed 5088 times
Hold outgoing properties.png (51.45 KiB) Viewed 5091 times
b.schuring
Works like a charm! This was exacly what I neededThanks!
