Pitstop 22 Update 1 Performance Issues M1 Mac Ventura
rhd_ole
Post by rhd_ole »
Hey All,
Has anyone experienced any delays or slow downs using PS after updating to Ventura on M1 Macs?
We have 4 workstations that updated and it is extremely slow to select global change such as changing a color. When you open the global change, and use the picker or when you try and build a Process color it just spins for up to a minute before you can any type or change anything. This is even worse if you have the inspector open as you do any color change. It's to the point we might have to make drastic change and downgrade the OS.
Thanks and look forward to a solution hopefully.
Re: Pitstop 22 Update 1 Performance Issues M1 Mac Ventura
Are you on PitStop Pro 2022 update 1? See the system requirements:
https://www.enfocus.com/en/support/syst ... quirements
If you are, please log this with support.
rhd_ole
Post by rhd_ole »
freddyp wrote: Thu Mar 30, 2023 10:00 am Are you on PitStop Pro 2022 update 1? See the system requirements:
I am, that's why I have mentioned the issue - Update 1 seemed to cause the issue. I'll log it with support.
Thanks.
