Pitstop 22 Update 1 Performance Issues M1 Mac Ventura
Posted: Tue Mar 28, 2023 6:31 pm
Hey All,
Has anyone experienced any delays or slow downs using PS after updating to Ventura on M1 Macs?
We have 4 workstations that updated and it is extremely slow to select global change such as changing a color. When you open the global change, and use the picker or when you try and build a Process color it just spins for up to a minute before you can any type or change anything. This is even worse if you have the inspector open as you do any color change. It's to the point we might have to make drastic change and downgrade the OS.
Thanks and look forward to a solution hopefully.
