Separate multiple sets of trim marks
saitok
Post by saitok »
I want to split a page of PDF which has multiple sets of trim marks to multiple pages which has single set of marks on each page.
I know we can do that if the position of the marks is fixed even if roughly.
However, it's not fixed in this case.
If I can know the coordinate(X,Y) of the marks using something like an image recognition engine, I think I can split by Switch.
Is there any good software or command like that?
Regards,
Re: Separate multiple sets of trim marks
There is a PitStop Action "Check if visual content exists" that uses image recognition. With this Action you could search for the top-left marks and for the bottom-right marks separately and afterwards analyze the report to find the locations so you can cut the PDF into pieces. Then you can use the Action "Use trim marks to set page box" to set the page box correctly on the individual parts. Not straightforward!
saitok
Post by saitok »
Thank you Freddy,
Very interesting.
I've never treid this.
However, when I take a mark into the Action, an alert like the screenshot is shown. :(
Regards,
What if you try the complete left side of the marks? And the same for the right side? Or the top and the bottom?
Share the file please.
saitok
Post by saitok »
I don't know what is the preferred way to share, but you can download the PDF here.
https://we.tl/t-CG9bpkpCIu
Only case I can grab the marks without the alert is grabing all marks on the 4 corners at once.
However, the Action created like that doesn't find anything on my PDF.
Thanks,
saitok
Post by saitok »
I could do this using this flow.
I guess it includes Action Lists we need.
But I also use Shell script in this to compare coordinates provided by Preflight report.
minX.sh is like:
#!/bin/bash
IFS=$'\n'
numbers=($1)
echo ${numbers[@]} | awk '{
min = $1
for(i = 2; i <= NF; i++) min = $i < min ? $i : min;
print "<minX>" min "</minX>"
Regards,
複数トンボの分割.sflow.zip
(190.29 KiB) Downloaded 901 times
