Math Expressions With Metadata
rgpepper
Post by rgpepper »
Trying to do this calculation that involves 2 pieces of metadata, as part of a multi-line with variables, for an email body. I can't seem to find the right formatting. I either get nothing but "Shortage % %", or I get the entire formula exactly as it is below. How do I format those 2 pieces of metadata to be resolved as numbers, in an equation?
Shortage %: [Switch.Calculation:Expression="((1-(["Metadata.TextIndexed:Path="/field-list/field[tag='Quantity Good']/value",Dataset="Submit",Model="XML"]/["Metadata.TextIndexed:Path="/field-list/field[tag='Quantity Ordered']/value",Dataset="Submit",Model="XML"]))*100)"] %
Re: Math Expressions With Metadata
Your calculation formula worked for me, but I used PrivateData for the values since it was easier to set up for testing.
I see that you have the Metadata as TextIndexed try instead with just Text
tdeschampsBluewest
Post by tdeschampsBluewest »
			1-(
		*100
The only way it could fail, is if ["Metadata.TextIndexed:Path="/field-list/field[tag='Quantity Ordered']/value",Dataset="Submit",Model="XML"] is equal to 0 or null.
