Hi.
I have a private data looks like abc: 1; def: 2; ghi: ; jkl: 4; xyz: ; and trying to delete everything without digit value using script expression:
const allCities:string = await job.getPrivateData("allCities");
const allCitiesArray:string [] = allCities.split(";");
const pattern = /\b\d+\b/;
const filteredArray = allCitiesArray.filter((item) => pattern.test(item)).toString();
await job.log(LogLevel.Debug, filteredArray);
return filteredArray;
As a result, I would like to get - abc: 1; def: 2; jkl: 4;
What's wrong in my code or do we have other way to do this?
Remove part of private data
Arsen Manukian | Solution Architect | Phoenix & Griffin
- tdeschamps
Re: Remove part of private data
Hi Arsen,
Hope you are well ?
Your code work great, but it will return an array with the ".toString()" which is not the same format as the one prompted in the first place.
Since i think you want a concatenate string as the one in the private data, you need to use "join(" ;") instead of ".toString()"
TypeScript lang example
Hope you are well ?
const allCities:string = "abc: 1; def: 2; ghi: ; jkl: 4; xyz: ;"// await job.getPrivateData("allCities");
const pattern = /\b\d+\b/; ///\w\:\s\d+\b/;
const filteredArray = allCitiesArray.filter((item) => pattern.test(item)).join("; ");
Merci beaucoup, Thomas.
I'm learning to use the scripts in the Switch a little at a time.
Now everything works as I wanted!
