select specific xml-value
FlorianDSK
Post by FlorianDSK »
Hello all
Is there any way to change a specific xml-value in Switch BUT only if the word 'bumper' occurs in that row for example and and all other values that may appear remain untouched?
As an illustration:
XML1
/jobs/order/productDescription = bumper (finds bumper and changes this value e.g. to adhesive foil outdoor)
XML2
/jobs/order/productDescription = sticker (does NOT find the value bumper and thus remains unchanged)
Many thanks
Florian
Re: select specific xml-value
The String Replace app should do the job for you.
https://www.enfocus.com/en/appstore/pro ... ng-replace
FlorianDSK
Hello Jan,
That worked out great.
Many thanks
FlorianDSK
The tool shows a strange action.
It searches for a certain value in a total node and then exchanges it with another value.
However, if this value is not present, it writes this value to the beginning of the XML.
As an example:
XML structure
<?xml version="1.0" encoding="UTF-8" ?>
Jobs
Job
item: Indoor sticker, A6, laminate
Format: A6
Job
item: Outdoor sticker; A7, without laminate
Format: A7
Job
Article: Special sticker, free format, without laminate
Format: 210x210
It searches for free format and replaces it with the value it finds in 'format'.
Now he notes all the values in Format, even in the nodes where there is no free format, and writes them to the beginning of the XML:
A7A6<?xml version="1.0" encoding="UTF-8" ?>
Jobs
Job
Format: A6
Job
Format: A7
Job
Article: Special sticker, 210x210, without laminate
Format: 210x210
How can you get around that?
Many Thanks
